Ir para o conteúdo principal
Model A1419 / Late 2012 / 2.9 & 3.2 GHz Core i5 or 3.4 GHz Core i7 Processor, ID iMac13,2
330 Perguntas Visualizar todos
Does a MB Air 2011 SSD fit into iMac 2012?
I've got a defective 13" MB Air from 2011 and wonder, if its SSD fits into my 2012 iMac to set up a Fusion Drive. Do you have any experience, if this works? I mean the SSD Connector at the back of the iMacs Logicboard near the Connectors.
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
1 resposta
Yeah, both of them have same connector. It should fit perfectly!
Good luck!
Esta resposta foi útil?
Pontuação -1
1 comentário:
So, this information is incorrect. Just opened my iMac…
The connector in the iMac 2012 is unique and not used anywhere else by apple. SSDs for the iMac 2012 fit ONLY in the iMac 2012. Maybe it also fits into the 21"-iMac, but not all models of the 21"-2012-iMac have a ssd-connector soldered. This depends on the processors.
por
Adicionar a sua resposta
Sebastian será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 135
