Out of date or missing drivers
I ran a scan on my laptop from Universa lDriver Updater it showed 19 out dated or missing drivers
Esta é uma boa pergunta?
In general it's best to avoid driver update programs. At best they usually try to sell you something you can get for free, at worst they contain malware. Uninstall it. Then, go to the official Asus computer website, click support, enter the exact model number of your laptop and it should show you a couple of options, one of which will be to see available driver updates for your computer. It's worth mentioning, a lot of technicians will tell that if you're not currently experiencing a driver-related problem then the benefit of updating your drivers is not worth the risk of the update causing a new problem
Esta resposta foi útil?
You can use the driver updater to get the solution to your problem.
Junk files and outdated or missing drivers are those key point which decrease your productivity and system performance. So it would be great for your pc to update your drivers and boost PC speed.
Driver updater software helps to improve the system’s performance by keeping all drivers updated with the latest available drivers.
Outdated or missing drivers can slow down your system or cause hardware glitches. You can update them using Universal Driver Updater or manually via Device Manager. For a safer, all-in-one approach, try Advanced Driver Updater by Systweak, which automatically scans, downloads, and installs the latest compatible drivers for your PC.
Últimas 24 horas: 0
Últimos 7 dias: 11
Últimos 30 dias: 31
Ao todo: 487
