Is there a Manual firing option?
Can I manually fire the Nerf Dart Tag Swarmfire with the device not turned on?
Esta é uma boa pergunta?
The power switch is found on the top of the Nerf gun near the stock end. The only way to use the Nerf gun is to turn the switch into the "on" position, it does not have a manual firing feature.
Esta resposta foi útil?
You could if you found a way to put some sort of hand crank on it
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 12
Ao todo: 358
