Ir para o conteúdo principal
Repair information for the Logitech K750 wireless solar keyboard. First available on Amazon in 2011. Model numbers: 920-002912 (Windows), 920-003472 (Mac).
Changed battery but still no signs of life?
I have bought and replaced the battery with an Maxell ML2032, but the keyboard doesn't show any signs of life. There is no green or red LED in the top right corner and the keyboard is not found by the unifying software. Each of the solar panels gives about 1.5v output when tested with voltmeter and the battery itself gives just over 2.8v (the old battery has less charge and gives about 1.2v).
Is there anything else that I might be able to do to fix the keyboard, I don't want to have to replace it?
Thanks in advance for any suggestions.
Scott.
Esta é uma boa pergunta?
Pontuação 12
1 comentário
same here. you are not alone
por
Adicionar um comentário
3 respostas
Pergunta mais útil
Turn the battery over. With the keyboard right side up you should see the smaller negative side up.
Esta resposta foi útil?
Pontuação 4
1 comentário:
Just for clarification, the correct position of the battery is shown in the step 5 of how to change the battery: Logitech K750 Keyboard Battery Replacement
por
You could have a look at the power (On Off) switch. On my K750, this switch is starting to fail causing symptoms like you describe.
Pontuação 3
2 comentários:
I have this problem (Logitech has put obsolescence on the switch too to kill the keyboard). Curiously, the switch is always "on" and drain the battery even if we do not use it.
Have you solve the problem ? How ?
Thanks.
por
Turn the battery over before anything else
por
Hi Scott, my guess would be that the logic board may need to be replaced OR a cable could have come dis-connected from the board or the battery itself. I suggest trying to re-install the new battery.
Pontuação 2
7 comentários:
seems reinstall makes no difference. for me zero power even with new battery. how to fix worn power switch?
por
I have two of theses, both went down within the last month, I changed ther ML2032 battery in both, still no life, Logitech are holding something back from us regarding the answer!
por
por
Turning battery over was the game changer, installed replacement wrong and then just put old one back in (battery goes in opposite of what you'd think). Also used a hack of turning off keyboard, holding CAPS LOCK down and pressing buttons for 5 seconds and then turning keyboard back while under direct light.... .those 2 things revived my keyboard.
por
Larry Jackson and Rob Lazott, you both just made my K750 keyboard go from dead to back to life! Thanks so much for the tips on turning over the battery AND the CAPS LOCK trick. I'm back to seeing green! :D
por
Exibir mais 2 comentários
Adicionar a sua resposta
scott adam será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 19
Últimos 30 dias: 81
Ao todo: 7,805
