Ir para o conteúdo principal
AM3 CPU in AM2 motherboard?
Hello,
I just got a AMD Phenom II X4 955 from the Salvation Army for $1.99 and there are no pins bent. It says it is a socket AM3. I have a socket AM2 mobo laying around doing nothing. The CPU fits in the socket, but idk if it will actually be compatible. Does anyone know if this will work? I don't want to buy a new PSU, case and hdd just to have to buy a new mobo too.
Esta é uma boa pergunta?
Pontuação 0
1 comentário
Just go to manufacturer of motherboard website and check for compatible CPU's - may need BIOS update.
por
Adicionar um comentário
3 respostas
Pergunta mais útil
Google this: Will am3 processor work in am2 motherboard
Esta resposta foi útil?
Pontuação 2
Unfortunately, you are only able to run AM3 processors on certain AM2/AM2+ motherboards, and only if the manufacturer provided a BIOS update supporting it. On the ones that are capable, you still won't have the full capabilities, as the socket/chipset weren't designed for it (such as Hyper Transport). Your best bet would be to find an AM3 motherboard, rather than gamble with your current one.
Pontuação 1
Stick it in if it doesn’t support it, it will not post, then take it out and put the original CPU back in, nothing gained nothing lost.
Pontuação 0
Adicionar a sua resposta
Gigabit87898 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 7
Duração total: 1,049
