How do I turn safe mode off?
Safe mode came on and now I have no volume and I can't power down my tablet.
Esta é uma boa pergunta?
The last I heard you put a pin in where earphone goes and hold it
Esta resposta foi útil?
This is the second time I had the problem all right it's very simple turn off your tablet then take something sharp like an earphone or something sharp the end where it would go in in the little hole at the top where you would put the earphone what you do is you put it in you leave it there on the counter 20 pick it up push it back in at the counter 20 as you're turning it turning it on it should be fine
Beside headphone plug and n there is a reset hole u put a pin in and hold down for a few seconds. This should correct the problem.
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 12
Ao todo: 1,117
I don't have this problem it just says safe mode in the corner
por Midnight Wolf
