Ir para o conteúdo principal
Anyone having a Nikon MD-12 Repair Manual, Wiring Diagram or Picture?
I have an old analog Nikon camera with a MD-12 Motor Drive in which three electrical wires have released from their soldering.
I wonder if you could please help me with a pdf repair manual or a picture of the wiring diagram for the circuit board that is connected to the shutter release switch? The wiring diagram is in the repair manual but an ordinary picture of a circuit board with the cables attached is also OK.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Pergunta mais útil
@ostlind this is going to be tough since we cannot see which PCB this is and where the wires are coming from or going to. A total view of the board would help, but I can imagine that it will be a PITA to completely remove it. Something like this
would help us to help you:-)
Anyhow, this will definitely help you out since it contains everything you need md12sm.pdf Make sure that you create a couple of guides when you repair this. It will come in handy for other people looking for answers like you.
Esta resposta foi útil?
Pontuação 2
1 comentário:
Thanks @oldturkey03 for the manual, it solved my problem! I already had the motor disassembled so there where no point in making a guide but I'll keep it in mind for upcoming objects!
por
Adicionar a sua resposta
Sven Ostlind será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 26
Duração total: 1,972
