Ir para o conteúdo principal
A Coolpix S7000 foi lançada em 2015. A câmera possui zoom ótico wide de 20x, recursos de Wi-Fi e tecnologia de comunicação por proximidade (NFC).
Why has the camera locked up?
Camera is frozen. Screen is on (special effects/image mode) & lens extended. Camera will not turn off or respond to menu, playback or directional keys. What do I do to un-freeze /unlock it?
Esta é uma boa pergunta?
Pontuação 3
Adicionar um comentário
2 respostas
Pergunta mais útil
Didn't see any answers, so I simply opened the battery/SD compartment and removed SD chip then battery. Put them right back in and everything is working again as it was before it locked up.
Esta resposta foi útil?
Pontuação 7
12 comentários:
I ended up trying this and it actually worked, thank you!
por
yes, it worked! Thank you for sharing your idea.
por
Thank you, that worked!
por
Thanks a mill...it really worked
por
This worked untill I try to zoom in and then it freezes again
por
Exibir mais 7 comentários
The best solution is using a SD Memory Card with great data transfer rate, like Sandisk Extreme Pro 95MB/s.
After change SD Memory, the camera has not been frozen or made this issue! Hope it help.
Pontuação 1
1 comentário:
My memory card is a SanDisk Extreme 64 GB with "45 MB/s" on the label. Is this really too slow for photographing my dogs in the Scene Sport mode of my Nikon CoolPIX P950? It may be time for a faster card.
por
Adicionar a sua resposta
Sarah Moles será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 28
Ao todo: 11,422
