motherboard take 9 volts but need 5 volts
smps power 5volts but motherboard show 9 volts,but smps has no problem
Esta pergunta é pertinente?
Pontuação 0
3 comentários:
We are not mind readers nor clairvoyant. What are you working on, make and model number.
por
Smps connect to cpu motherboard
por
@rajcj
More information is needed to help you.
What is the make and model number of the motherboard?
What is the make and model number of the SMPS?
Why do you want to do this and what is wrong with using an ATX PSU which is designed to be connected to most PC motherboards. You can't connect directly to a CPU
por
Adicionar um comentário
