Ir para o conteúdo principal
Repair guides and support for home heating, ventilation, and air conditioning system repair.
346 Perguntas Visualizar todos
Amanda ac and heating system is showing br
Hi my Amanda ac and heating system is showing br when I tried to turn on my ac can anyone help me fixing my ac problem I tried the test it was working good but later on it shows the same code br
Esta é uma boa pergunta?
Pontuação 2
5 comentários
sunjaibomma what model Amana is your AC? what have you tried so far to fix it? Where are you located and how is the regional power grid? Any chance that you are having local power issues?
por
I get four lines instead of two when I am trying to program the unit and it does not let me go any further all i can scroll is 00 to 99?
por
Okay I am at my job at a hotel ans I have a few ptac units that are hooked to thermostat and all of a sudden go into code BR ive resetted unit and still does the same exact thing. Model is pth094g35axxxaa.
por
I have two Amana ptc123g50's. I was sweeping the kids room and accidentally ran over the thermostat wire that plugs in below the display panel. It read "F1" immediately and will not reset or turn back on! HELP PLEASE
por
So I have tried to reset my unit that has code BR.. I have checked voltage and changed braker and outlet and still say BR.. tried doing reset by holding down hot and cold at same time.. is there any other
por
Adicionar um comentário
2 respostas
Solução escolhida
sunjaibomma Amana AC common error codes
CODE = br
FAILURES STATUS = Brown Out Protection engaged. Power was lost or voltage is low.
DISPLAY = N
ERROR LIGHT = N
SUGGESTED ACTION = Check for incoming power at correct voltage.
Let us know what model your Amana is so that we can double check this.
Esta resposta foi útil?
Pontuação 4
5 comentários:
Model #FTC123B35AMNP
por
PTC123E35AXXXAB
Help me out with resetting mine. Mine is showing Br also.
por
Tried reset but not working
por
PTH153G50AXXXCA same problem.... Showing br code.
por
fishagua so what did you check?
por
Just unplug, wait 5 seconds, hold the heat and cool buttons down at the same time (not the plus and minus ones), plug unit back in while continuing to hold heat and cool buttons down, wait till red light appears next to off button. Done. This will clear the BR and reset unit back to factory defaults.
Pontuação 2
5 comentários:
Thanks very much for this information.
por
Unplugging and holding those 2 buttons doesn't even
por
Tried that method 4 times,. Still goes back to br code..
por
Model pth094g35axxxaa
por
Check your circuit breaker if it's winter remove the thermostat and then put it back in if it's summer probably low on freon or dirty coils filters bower etc
por
Adicionar a sua resposta
sunjaibomma será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 29
Últimos 30 dias: 101
Duração total: 22,571
