Ir para o conteúdo principal
Repair guides and support for LED, LCD, HD and other Vizio TVs.
931 Perguntas Visualizar todos
Should I try Power supply board or main board on led tv?
LED tv, started with speakers, turn on tv get normal sound for about 3 min then an unbearably loud static noise. About a month later the screen went black, turn the tv on good picture for a couple min then black. A week later doesnt turn on at all and just slowly blinks power light. I seriously doubteach component just failed back to back. What do ya think? Power supply board or main board? Didnt notice any bad capacitors...its a 600$ tv might as well try a 40$ board...
Esta é uma boa pergunta?
Pontuação 0
7 comentários
@jorricha any pattern to this " just slowly blinks power light"? What model is your Vizio?
por
@oldturkey03
Vizio m471i-a2
As far as "blink" if i plug it in without pressing the power button the white power light slowly goes from off to dim to fully lit to dim to off over & over in about a 5 second cycle
Thanks
por
Just some more info...When the loud static noise started at the beginning of all of this, i hooked up a soundbar to audio out and the sound came through there as well.
por
@jorricha any chance you can take a couple of good images of your boards and post those with your question? Use this guide Adicionar imagens a uma pergunta já existente for that. It'll allow us to see what you see.
por
@oldturkey03 Hope that helps, looking @ it again the tops of the 2 on the main board "2n 470 25a" seem to be protruding a little. The tops of all the caps on the power supply are flat.
por
Exibir mais 2 comentários
Adicionar um comentário
3 respostas
Solução escolhida
It ended up being the Main Board for anyone that has this same problem.
Esta resposta foi útil?
Pontuação 0
@jorricha the caps all look good. There is something tha looks odd on your power supply. It appears as if something got a bit hot. Of course there are no schematics readily available so I can not determine where those jumpers come from or what they bridge. On a hunch based on the discoloration I'd go with the power supply. ~$25 on ebay DPS-111EP
Pontuação 0
1 comentário:
Thanks Ill give it a try & see what happens
por
I have a vizio m502i-b1 I unplug it and now it now come on
Pontuação 0
Adicionar a sua resposta
Jordan será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 13
Duração total: 16,046
