Ir para o conteúdo principal
Lançado em novembro de 1998, identificado pelo número de modelo HKT-3020.
Controller Port 1 doesent work
Hey Everyone,
I got a Dreamcast from Ebay, but the Controllerport A/1 doesent work. All the other, B/C/D works perfectly.
I hope you can help me
Esta é uma boa pergunta?
Pontuação 0
3 comentários
Do you know how to solder? If you don't, your best bet will be to purchase a replacement controller board off ebay and simply swap out the part.
por Compartilhar
yes i can solder, but why?
i read a lot of the problem on the internet, but that is always all controller prots, not only one. so i think the problme withe the fuse coulnd't be
por Compartilhar
The reason I ask is that controller port board on the Dreamcast is among one of the more friendly parts for soldering, since all the components are through-hole. I would do a continuity test on the fuse, just to rule it out as a problem.
por Compartilhar
Adicionar um comentário
1 resposta
Solução escolhida
This guide would be the easiest, if you don't want to solder it
Substituição da porta de controle do Sega Dreamcast
This guide would use a little more work, but you could individually change out one controller port
Also found this on eBay
https://www.google.com/aclk?sa=L&ai=DChc...
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
thunderblrd será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 19
Ao todo: 1,897
