Ir para o conteúdo principal
Esta página do dispositivo mostrará aos membros como substituir várias peças da Canon PowerShot SX260 HS. Isso inclui a substituição da tela de reposição, placa-mãe, bateria de reposição e botão do obturador.
On and Off switch corroded
After many trips to the beach and I KNOW sunscreen/sand/sweat etc, my on/ off switch became really hard to work. I would have to press it really hard, or at a certain angle to get the camera to power on. Once on, the camera worked perfectly. Finally came the day where I could not power the camera on anymore. I know the switch or button either needs cleaned or replaced. Maybe the electric contacts have become corroded. Any idea on how to do this?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Hi, there is a site called electrotanya or something like that. THey have free SM manuals. It will help you with a teardown so you can get to the root of the problem. A corroded button can also mean other corroded parts... In my experience the gold fingers or gold contacts can easily be fixed with a good quailty conductive epoxy silver. That usually does the trick very well.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
thethompsons será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 14
Ao todo: 272
