Ir para o conteúdo principal
Guias de reparo e ajuda para resolução de problemas em máquinas de gelo KitchenAid.
Ice maker in door
Have the front cover off need to get to ice motor need to remove inside despener insert
Esta é uma boa pergunta?
Pontuação 0
2 comentários
Still need to know how to get cover off to get to ice motor
por Compartilhar
@clairereese post some iamges of your door and the ice make assembly. Let us see what you see so we can maybe find the right answer for you. Use this guide Adicionar imagens a uma pergunta já existente for that
por Compartilhar
Adicionar um comentário
1 resposta
Solução escolhida
You should be able to put your fingers under the bottom of the bin to the back and pull it horizontally straight out.
It's according to which type you have. Here one: https://www.youtube.com/watch?v=UHi59JFB...
Here's another type:
https://www.youtube.com/watch?v=OZR1rFBD...
It would help to know you model number. By your description it sounds like an ice maker in a refrigerator but it could be a stand alone unit.
Would you mind telling us what the problem is before you pull it?
UPDATE
It might not be the motor.
Ice Maker Assembly
One component of the ice maker assembly might be defective. Since many of the ice maker components are not sold separately, you may need to purchase and replace the entire ice maker assembly. Before replacing the ice maker assembly, check the water inlet valve, water line, and fan. If none of these parts are at fault, and the freezer temperature is at least 15 degrees Fahrenheit, replace the ice maker assembly.
Cause 1
Dispenser Control Board
The dispenser control board governs most of the functions of the dispenser system. If the control board is faulty, it may stop supplying power to the entire dispenser system. If only one dispenser part is not working, test each of the dispenser components before testing the control board. It is more likely that a single part has failed. If the entire dispenser system is not working, the control board is more likely to be at fault.
Cause 2
Dispenser Switch
The dispenser switches send voltage to the dispenser. If one of the dispenser switches is defective, the dispenser will not work. To determine if a dispenser switch is defective, use a multimeter to test each switch for continuity. If a dispenser switch does not have continuity, replace it.
Cause 3
Dispenser Actuator
The dispenser actuator interacts with the dispenser switches, which power the auger motor and other dispenser components. If the dispenser actuator is broken, it may not activate the switches properly or at all. Inspect the dispenser actuator—if it is broken, replace it.
Esta resposta foi útil?
Pontuação 1
5 comentários:
The ice maker will not despense ice though door model ksrg22ftss01
See no su4346970 motor does not go on
por Compartilhar
You did not an sewer my ? How do remove the inside cover removed the four screws prided around cover is it held in by the foam inside door need to get to motor
por Compartilhar
Well you didn't answer my question as to what the correct model number is, o I have no idea of what you have.
por Compartilhar
model no. ksrg22ftss01
Serial no. su4346970
por Compartilhar
Adicionar a sua resposta
jeff gilmor será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 13
Ao todo: 1,563
