How to replace charging port?
My charging port is mashed in.
Esta é uma boa pergunta?
hello,
i do not know the model that well, but normaly it is soldered to the mainboard.
If it is soldered to the mainboard : you have to unsolder the old one and replace it with an other charging port , solder it properly .
there are many guides to solder ports on ifixit
good luck,
Kind regards,
Kevin
Esta resposta foi útil?
see explanation in other post you have.
You will have to solder. (most likely)
Kevin
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 19
Ao todo: 737
