Ir para o conteúdo principal
Repair guides and disassembly information for Huawei's Android-based smartphones.
Internal storage damaged and is now unavailable
Everytime I turn my phone on it always says "internal storage damaged and is now unavailable. Please choose one if the following"
A) restore factory settings
- but it won't let me choose this option.
B) restart phone
- I've already done it but it has gone back to the same thing.
Esta é uma boa pergunta?
Pontuação 28
4 comentários
what is the solution this problem huawie internal storage is damage
por
If you can do a factory reset then attempt it this may repair the problem but in most cases the memory in the phone is corrupted and not repairable . If you can preform a factory reset you will lose all your data but you will have a usable phone again .
por
wipe data wil solve your problem but you will lose your data tested by me
por
@emanco80 he does not need the data tested by you, so I think it's fine if he looses that! :)) learn how to write first, idiot! and no, it will not solve the problem! how can a data wipe repair broken memory clusters? just go away man
por
Adicionar um comentário
1 resposta
Solução escolhida
probelm with EMMC IC no way to repair only change IC
Esta resposta foi útil?
Pontuação 8
Adicionar a sua resposta
kaycee ngawhika será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 5
Ao todo: 16,067
