Ir para o conteúdo principal
Câmera DSLR digital Nikon D600 com sensor CMOS full-frame de 24,3 MP
How do I open this ZIF? Connector?
Imagem
Imagem
Hi,
This is the underside of top of my D600 that I dropped. To mend the top display I had to remove this board and do some soldering.
I pulled out the ribbon that goes into the white connector at the bottom of the board as you view it - see attached photos.
I pushed back the ribbon, although it did no go completely in. After re-assembling the camera I found the wheel under the forefinger inperative.
How do I unlock this, I have so far not tried too hard as I must not break it!
hope someone can help,
John
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
every zif connectors have a plastic lock on it, just unlock with a small flat screw driver and pull out the ribbon cable carefully, when reconnecting extreme care should be taken.
Esta resposta foi útil?
Pontuação 0
The black part of the connector is the part that flips up to release the ribbon cable. Still be gentle with it.
Pontuação 0
Adicionar a sua resposta
John Bishop será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 10
Últimos 30 dias: 31
Ao todo: 945
