Ir para o conteúdo principal
Touch ic problems iPhone 6plus
So i got a iPhone 6 plus today with the grey bar on top indicating that the touch ic was going bad, or not soldered well. i have replaced the cumulus chip and now i have no grey bar, but the touch is a little less responsive near the letter U if you were texting. or trying to slide backlight brighter 3/4 of the way it stops.
Do you think this is a problem with the chip i replaced or is this caused by the mason chip?
Esta é uma boa pergunta?
Pontuação 0
1 comentário:
Is the screen that is on the phone right now have any signs of physical damage at all?
por
Adicionar um comentário
2 respostas
Screen could possibly been replaced. It is known to happen that the Touch ID will stop working once a screen is replaced. Part of the deal made when the lawsuit happened over Error 53 (source: TechCrunch).
Esta resposta foi útil?
Pontuação 0
1 comentário:
The reason the Touch ID isn't working after the screen replacement is only because of two reasons;
1. the home button was damaged during the repair.
2. the home button flex cable was damaged during the repair.
I saw it happened only was when the Touch ID stopped working after a repair for no reason on an iPhone 5S and after I reset all the settings (in settings) it was fully working again.
por
first of all try to install a new screen to see if it helps. there is no harm in trying a new screen.
if it didn't help any, try re-soldering the chip back in the place, maybe you missed something while soldering the IC. if yet it's not solved then I think it safe enough to say that It is indeed the touch IC.
Pontuação 0
Adicionar a sua resposta
Jessica Ward será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 1,063
