My note 5 got wet
my note 5 got wet not much but now the back button is not working what should i do to get it back working
Esta é uma boa pergunta?
If its just the back button then you can replace it and all will be right
Substituição da tela LCD, placa USB e botão home do Samsung Galaxy Note5
There is a small cuircut board that can be replaced
They can be purchased on amazon or ebay. Sorry there not available here
Esta resposta foi útil?
hi i droped my samsung galaxy note5 in the water and i dont no what to do?
My charging port got wet and my phone won't charge correctly, I don't know what to do.
Firstly you can try to make the charging port dry,such as blotting paper,hair drier with very little wind,etc.
If it is still not work,I think you need buy a new charging port flex cable and replace it.
Well instead of paying for it to get fixed you can easy just let it completely dry and backup all of your photos,videos,and contacts. And master reset it. That's what I did to mine and I dropped it in a fish tank
I cleaned a clients note 4 thoroughly. Still didn't work as some component chips are burnt.
Hi I have a stylo 5 and I just got a stylo 5 and I dropped it in water. After i put it in rice it would only turn on and then say it has no power. My phone won't charge when I plugged it in or show the light that there is a charge. I put it back in the rice to try to dry it out again but I was just wondering what else I could do to try to get it to start charging
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 12
Ao todo: 6,582
