Ir para o conteúdo principal
Announced in March 2015 and released April 10, 2015, the Galaxy S6 Edge is the curved-screen version of Samsung's newest flagship smartphone.
237 Perguntas Visualizar todos
Pink line down the screen, presumably from drop damage.
Pink line down my screen from drop I believe, there is no damage to the screen just internals. With pressure, placd at the UN in the SAMNSUNG name, it goes away til the pressure is gone and it returns.
Esta é uma boa pergunta?
Pontuação 2
1 comentário
Adicionar um comentário
2 respostas
Pergunta mais útil
@guardianactual could be dislodged connector and/or a broken TAB on the LCD itself. You'll have to disassemble it and check the connector first, make sure it is properly seated. If it is, you will most likely have to replace the LCD itself. Check this teardown to see how you get into your phone.
Esta resposta foi útil?
Pontuação 2
https://youtu.be/Ed2VvM7uEIE
Try this method, work for me :)
Pontuação 0
Adicionar a sua resposta
Jon williams será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 4
Duração total: 5,218
