Ir para o conteúdo principal
Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
speaker phone speakers not working
This is not an earbud issue. I have never plugged mine in. One day I was using the Speaker option and noticed that the sound was scratchy. The next day the phone did not ring it only vibrated. I have a very quite ringtone plus vibrate for incoming calls. The ring sound comes out of the speakers as well as the voice so right now all I have is the vibrate option. Listening out of the speaker by the ear works great. My ringer and speaker are at maximum volume. I have not gotten the phone wet, but I do live in Houston, Texas which has high humidity. Is there something I can do to fix this. I can take the phone apart, but would like to know what I am to do when it is open.
Thank you,
Nicole
Esta é uma boa pergunta?
Pontuação 1
1 comentário
hi nicole, have you solved your problem yet? noticed this remains unanswered... if it's still a problem we can help or you can search the troubleshooting section for help.
por
Adicionar um comentário
1 resposta
Solução escolhida
Hey, check if the speaker flex is conneted or if its not brocken... I had the same problem with mine.. i just dissasambled it and indeed, the flex was brocken, as always, apple fix parts are very xpensive, i just adapted to wires coming from the iPhone speaker to the dock conector were its going plugged.. It still works very well for me.. i hope to be helpfull!!!
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Nicole será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 5
Ao todo: 3,713
