Ir para o conteúdo principal
Uma edição atualizada do Samsung Galaxy S II lançada em 2013, identificável pelo número de modelo GT-I9105/P.
How can I fix my screen?
I droped my phone, actually it's not the first time but it was a hard one, and when i check it there was a black spot on the screen, i knew then that it's broken.
But after a few minutes the spot covered all the screen; though i still can hear the lock screen or when i turn it on so it's still working.
i think i need to change the screen or something like that but i don't know how ?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Yes you can replace the screen but the cost of replacement would probably be more than the phone is worth I see on ebay the going rate is 125 for a replacement and you will need a complete replacement LCD digitizer and glass complete .
http://www.ebay.ca/sch/i.html?_odkw=Sams...
this is a tear down video for your phone
https://www.youtube.com/watch?v=pDkvz9fU...
Everything can be fixed but not everything should be . If you have important data on the phone even with a broken screen you should be able to connect and retrieve the info unless your phone is password locked
Hope this helps
Esta resposta foi útil?
Pontuação 3
1 comentário:
thank you so much I really appreciate it.
por
Adicionar a sua resposta
simo5991 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 19
Últimos 30 dias: 25
Ao todo: 354
