Ir para o conteúdo principal
Device and repair information for the 60" LED HD TV by Samsung released in 2013, model number UN60FH6003FXZA.
Back light dark on top
Dark the top is black
Esta é uma boa pergunta?
Pontuação 2
6 comentários
@duba is it just darker or is it black? do you still see things on that part of the screen?
por
I have the same problem, my screen is dark in the top.
por
I have a similar problem but I have no image or sound it just blinks now on and off and the top of the tv is darker then the bottom I replaced the power board and the main board and still no fix need any tips!
por
I have the same problem. it started gradually getting worse now to the point the top is virtually un-viewable with the darkest at the top fading back to normal at the bottom. there is three cards in the back, has to be one of them i would think.
por
@georgesl not necessarily. Could be the LED strip that makes up your backlight. Repairable by disassembling the panel itself and hopefully getting an LED replacement
por
Exibir mais 1 comentário
Adicionar um comentário
1 resposta
Solução escolhida
@dube @lintaum this is most likely caused by a failed backlight. Could be the power board, the LCD or the inverter circuitry. This is a vague answer due to the fact that we do not have all the information.
Esta resposta foi útil?
Pontuação 3
Adicionar a sua resposta
Portia será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 13
Ao todo: 4,483
