Removing Display and Screen
Hello,
I have a Lenovo Yoga 700-14ISK with a cracked screen. I have ordered the replacement glass, thinking this would be an easy heat/pull/replace operation. However, that is not seeming to be the case. When I heat the glass, all the rubber and plastic around it become too soft to pull the glass off without damaging it.
Does anyone know of a walk-through on replacing this glass? I've only found the 13" version, and that is a totally different screen.
Thank you in advance!
Esta é uma boa pergunta?
1 comentário
Did you ever find your answer to your question? I too have this identical Yoga 700. Cracked screen, failing digitizer. I have the replacement screen on order... but now I'm worried as mine is looking more like it might be like yours with the glued screen. Maybe not the Yoga in this video, Help https://www.youtube.com/watch?v=WdZ-iZzW...
por kipwylie
