Ir para o conteúdo principal
The Samsung Galaxy S3 is a multi-touch, slate-format smartphone with eye-tracking ability, increased storage, and a wireless charging option.
459 Perguntas Visualizar todos
No power due to battery?
When I have my battery inserted correctly like this:
the phone doesn't turn on at all.
When I have it like this:
it turns on and works with no problem.
I tried with a diffrent board and it does the same, is it a battery problem?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Solução escolhida
if you tried a diffrent board, why don't try a diffrent battery ? I think it will fix your problem
Esta resposta foi útil?
Pontuação 1
Pergunta mais útil
Clean the battery gold points with isopropyl alcohol. Make sure it's at least 90% alcohol. Also clean the 4 golden connection prongs on the phone as well.
If that doesn't help try another battery like @cornelis said.
Pontuação 2
Adicionar a sua resposta
George será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 81
