Ir para o conteúdo principal
Reparo e suporte para os controles que acompanhavam o PS3. Lançado em novembro de 2007 (apenas no Japão) e em 2008 (outros países), o controle com bateria de lítio e seis eixos (CECHZC2) é simples de consertar.
Why does my controller randomly presses buttons?
Whenever I play a game the controller justs starts choosing options that match the buttons out of nowhere without them being pressed. For Example I'll play call of duty and all of the sudden I'll start switching weapons or shooting without me pressing the button.
Esta é uma boa pergunta?
Pontuação 34
14 comentários
Only difference with mine is it works normally on the charger as a wired controller why would this happen
por
Best guess is that your Bluetooth module is giving out wonky signals. Does it happen with other controllers?
por
As for mine, the controller works fine on another person's computer when I try but starts pressing itself randomly on mine
por
What I usually do is smack it against the floor until it works properly
por
I had the same problem. I then opened up my controller and cleaned the contacts. check this guide here: http://bit.ly/openps3controller
por
Exibir mais 9 comentários
Adicionar um comentário
8 respostas
Solução escolhida
I would suggest you open up your controller and clean the contacts. If things get stuck in there or if its grounding out for some reason across the contacts you'll get the behavior as described.
Use this guide to help you open it up.
P.S. the clear contact sheet that the buttons press on shouldn't be bent or crinkled.
Hope this helps.
Esta resposta foi útil?
Pontuação 17
5 comentários:
Thanks alot! It worked great!
por
Hooray! Glad to help. :)
por
por
My problem is when i try to remove the five 7.2 mm Philips screw, one of them got stuck and i couldn't remove the cover of the controller, pls help
por
But what if the same buttons are not functioning across all my controllers 4 plus so far the left and up d-pad buttons and I'm also getting the call of duty Black ops when I pull a grenade 3/4 of the time it just holds on to the grenade after pulling the PIN and it just explodes in my hand no matter if I'm manically smashing buttons or put down the controller and press nothing I just recently cleaned out the dust took it apart cleaned the lens and put it back together because it wouldn't read discs now it works perfectly other than this issue
por
I had the same problem. My controller randomly sent d-pad signals.
The fix was to thicken the contact foam that is pushing the contact strype against the board.
I just used some transparent tape.
Here's a video from someone on YouTube.
https://www.youtube.com/watch?v=cY4rLTpn...
Pontuação 6
What if the clear contact sheet is bent or crinkled?
Pontuação 0
the clear contact is the sensor and if that is dirty or bent it will screw the hole things up making the controller user
Pontuação 0
In some cases, it could simply be the casing.
In my case, at the top left just below indicator number 4, there is a small piece of plastic that snaps the controller together.
Being I got mine used, it has obviously seen previous repair and the previous owner damaged this plastic contact.
By opening up the base and carefully pushing this piece back in position with a flat head, the controller snapped properly in place. After screwing it back together tightly (the screws were also loose compared to factory) I resolved my phantom D-Pad issue.
I also resolved improper placement of the R2 trigger spring in the process XD
Pontuação 0
hopefully this works my PS3 controller isn't working very well it keeps pressing random buttons and it keep moving around by its self and its also really difficult to shoot in GTA and Call of Duty.
Pontuação 0
1 comentário:
Let us know. I'd be interested to hear if you find out new information about it!
por
hope this works too my controller make vehicles like motorcycles swerve left or right in GTA 5 so it makes me mad. I've only had this controller for 1 year and same for play station.
Pontuação 0
1 comentário:
Go to settings and turn off Motion Sensor for Bike.
That should fix the swerving
por
When i press the x button on my p3 controller the button gets struck in , same with my R2 button …..how do i resolve my problem.
Pontuação 0
1 comentário:
My ps3 controller keeps pressing random buttons and how do I fix that without opening the controller
por
Adicionar a sua resposta
Rasheen Barber será eternamente grato(a).
Visualizações:
Últimas 24 horas: 11
Últimos 7 dias: 62
Últimos 30 dias: 235
Ao todo: 280,482
