Why is my screen barely visible?
The screen for my Garmin device is not very visible, and is much worse than when I first bought it.
Esta é uma boa pergunta?
Try adjusting your screen brightness, if that does not work the device's backlight may be starting to die.
Esta resposta foi útil?
Try adjusting the contrast also. If that doesn't solve the issue, then there might be something wrong with the display itself. Then, you would have to replace it.
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 13
Ao todo: 367
