Why is my coffee not hot enough?
Whenever I try to use the Keurig, the coffee doesn't come out hot enough. Please help:(
Esta é uma boa pergunta?
You may have a problem with your water pump. See troubleshooting page.
Esta resposta foi útil?
The temperature can also be set on the display via the menu but it is generally a sign that something else isn't working.
Why isn't my coffee hot
If you change it in menu to 192° and it still comes out cold, go to ebay. For 20 bucks you can get a new tank/boiler, usually ships free. Not a fun repair but doable easily once the case is off
There might be three possible reasons if your Keurig is not hot enough
Últimas 24 horas: 3
Últimos 7 dias: 26
Últimos 30 dias: 102
Duração total: 15,443
1 comentário
It's not hot when I finish brewing
por Adele Martin
