Ir para o conteúdo principal
Touch and power button issues
Having some weird problems after replacing the screen on this iPhone. To start the screen did not work at all when I received the phone. During the repair I tore the cable that the home button connects to. I replaced that cable and now after replacing the screen the touch almost never works. I can try to swipe over to the unlock screen but it will only swipe over once or twice every 30 attempts. Also the power button sometimes just doesn't work at all and sometimes it works fine. Currently I'm going over the mother board looking for any damages but so far I have nothing. Anyone have issues like this before or know of a solution? I tried a completely different screen and the same problems are happening.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
The touch problem sounds a lot like a common problem in the iPhone 6 (plus), where the touch IC no longer makes proper contact.
Unfortunately the only permanent fix is to resolder the entire thing, which requires quite some expert skills.
It's kind of hard to find decent info on this problem, since Apple won't acknowledge it.
For more information on what exactly causes it and how to fix it: http://mendonipadrehab.com/entries/gener...
Esta resposta foi útil?
Pontuação 3
2 comentários:
Definitely a good read. Thanks for posting that link
por
Thank you so much for your help time to test my soldering skills
por
Pergunta mais útil
Clean the digitizer and lcd sockets with 90% isopropyl alcohol. Make sure you've secured your connections and make sure you're using quality parts
Substituição do conjunto do display do iPhone 6 Plus
iPhone 6 Plus Screen
I would also check and see if the phones been water damaged. That would also be a 90% isopropyl alcohol clean. As for the power button. Try to clean it, you may need to get another flex cable
iPhone 6 Plus Home Button Link Cable
iPhone 6 Plus Power Button Replacement
Imagem de Replace a screen compatible with iPhone 6 Plus. Includes all of the small parts preinstalled in the assembly. Features a 5.5 inch 1080 x 1920 pixel IPS LCD Display, Front Glass Digitizer Panel, Front Camera Assembly, Earpiece Speaker, Home Button Link Cable, and LCD Shield Plate.
Produto
$49.99
Imagem de Replace the cable that connects the home button assembly to the logic board compatible with the iPhone 6 Plus. This cable follows a channel in the LCD shield plate. Part #821-2658.
Produto
$14.99
Imagem de iPhone 6 Plus Conjunto do display
Guia
Nível de dificuldade:
Moderado
1 - 2 hours
Imagem de iPhone 6 Plus Power Button
Guia
Difícil
45 minutes - 2 hours
Pontuação 3
2 comentários:
Power button is working fine after giving the it a good cleaning
por
Oh, good! Glad you got it sorted
por
Adicionar a sua resposta
Jeremy Byers será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Ao todo: 2,367
