bulb working but not receiving signal from projector
have power, have bulb working but not receiving signal from projector. have bought new cord - the control buttons on the projector not functioning.
Esta é uma boa pergunta?
6m4cahs the issues with no image is usually related to :"
"- Ensure the Signal Cable and Source work (If you connect multiple sources at the same time, use the "Source" button switch)- Ensure all connectors are securely connected and aren’t broken- Check Main Board- Check Engine Module- Check DMD Board- Check DMD Chip"
Seems to start to get a bit complicated. Let us know if you are up to taking it apart and checking a few things. You'll need some hand tools as well as a multimeter. You want to take as many pictures as possible and post those with your question. For that use this guide
Esta resposta foi útil?
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 3
Duração total: 397
1 comentário
6m4cash do you have flashing or blinking lights from your LED's (Temp and lamp)?
por oldturkey03
