4-inch iPhone released in March 2016 with similar hardware specifications to the 6s. Available in Silver, Space Grey, Gold, or Rose Gold with 16/64 GB storage options. Model A1662 and A1723.
518 Perguntas Ver todas
Are home buttons from 5S interchangeable with SE?
I watched and read the entire iPhone SE breakdown. They mention several parts' interchangeability but did not cover the home button. Are these parts interchangeable? Can I use a 5S home button in an SE and vice-versa? (Please do not add information concerning their functionality after being switched; I am only concerned about fitment)
Respondido! View the answer Também tenho esse problema
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
Free shipping on all orders over US$100,00 or containing a Pro Tech Toolkit!
Visite Nossa Loja
4 Soluções
Solução escolhida
Kaye's answer was that the home button was not interchangeable, but the link he/she provided said the opposite. It looks like the home buttons are interchangeable, but as with other Touch ID home buttons, will not provide Touch ID functionality. Only the original home button on a Touch ID device will work 100%, but these will still click and perform the other home button functions.
Esta resposta foi útil?
Pontuação 0
Resposta Mais Útil
You can look at the APN printed on the cable, they are exactly the same.
Pontuação 1
Comentários:
Thanks, Tom. I don't currently have an iPhone SE at my disposal - did you look at part numbers listed on this site or did you compare part numbers in person with actual examples?
por
Well you can check the teardown pics. On the 5s, the APN is 821-2092-01, while on the SE, it's 821-2092-A. The first seven digits are the same. The difference at the end could indicate different colors or part vendors, but the part itself should be compatible.
por
Just tried 5S home button on an SE. Yes, it works.
Pontuação 0
do not think it worked. this blog you can have a look http://www.etradesupply.com/blog/iphone-...
Pontuação -1
Comentários:
According to the link, it does work. Most repair techs know that only the original home button in a Touch ID device can be used for Touch ID - replacement parts only need to have the click functionality, and this does!
por
i‘m sorry, you're right, i mean it still features the click functionality but not the touch id.
por
No worries; thanks for the link!
por
Adicionar a sua resposta
Ryan Alexander será eternamente grato(a).
Visualizar Estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 30
Últimos 30 dias: 162
Todo: 2,456
