Will not turn on
Our tv will not turn on. There is power to the plug. Is there a fuse that might need replacing, or do you have any suggestions?
Esta é uma boa pergunta?
@jrickfrye here is an image that shows the fuse.
If the fuse checks ok for continuity you are having other issues with the power board. If you know how to solder, you can purchase a power supply kit that will repair most common errors with the board. Or you can replace the board.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 2,053
2 comentários
@jrickfrye there is a fuse (couple) on the power board. Remember there is a reason why (if it did) a fuse blows. What model # is your TV?
Rep: 1
por oldturkey03
Model KDL-40V5100
por Rick Frye
