Ir para o conteúdo principal
Can I replace an HD Display with an HD+ Display?
Can I replace an HD Display with an HD+ Display or do I need some kind of adapter for the cable? I actually own an Elitebook 8460p but as it is not listed here I thought this would be the right place to ask.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Hi,
Here is a link to the service manual for a HP Elitebook 8460p laptop.
On p.37 it shows the part numbers for both the HD and HD+ screens and cables. As the part numbers for the cables (and obviously the screens) for each type of screen are different, you would think then that you would have to get the correct cable for the HD+ screen.
If you 'Google' only the part number you will get results for suppliers of the part.
http://h20628.www2.hp.com/km-ext/kmcsdir...
Hopefully this is of some help.
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Hanna Schrader será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 21
Ao todo: 948
