Ir para o conteúdo principal
O eMac foi um computador Mac com processador G4 tudo-em-um, projetado para o mercado educacional e lançado em abril de 2002. Foi o último Mac a usar uma tela CRT e foi vendido a um preço acessível para escolas e outras instituições.
Replacing CRT with LCD
Dear I know it is outdated but I have an e Mac G4 1.25 GHz machine which I love very much and am going to replace CRT with an LCD but I want to use its own power supply to run everything and have omitted the high tension components and now it switches ON but needs to connect the round IVAD board so I need the circuit diagrams of analog board and details of Vga Connector Pin 4&10 with yellow wires and said to be I2C line.
I will be very thankful if you can provide me on rinclairelectronics@Gmail.Com
Thanks anyway but please reply whatever.
Ramesh
Esta é uma boa pergunta?
Pontuação 2
3 comentários
Could you please tell me about conversion CRT to LCD, I have one eMac G4 700, and want to move CRT to LCD :(
por
What you want to know and technically what can you do in electronics, I mean at what level you can work and understand.
por
Oh sorry for missing this message. I can solder and have suitable instruments for that :)
por
Adicionar um comentário
1 resposta
Solução escolhida
Here is the pinout of a VGA cable. The VGA spec is a standard, so this should be universally applicable
Imagem
I couldn’t find a diagram of the board, but I did manage to dig up some info that could help. You will have to view it via The Wayback Machine as the original site is long gone.
https://web.archive.org/web/200603131248...
Esta resposta foi útil?
Pontuação 0
1 comentário:
Dear I've done my conversion following this post only but I couldn't get the LCD he used so all is working but as he said it black out as I start game.
por
Adicionar a sua resposta
Ramesh Mistry será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 10
Últimos 30 dias: 40
Ao todo: 1,748
