Ir para o conteúdo principal
16:9 LCD monitor with a 1600x900 resolution display.
I can barely see the screen
I can barely see the screen and adjusting it makes no difference
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
shawn sounds like your backlight has failed. Most common cause for that are bad capacitors. Your monitor does not have a separate inverter but it is part of the power board. Start by disassembling the monitor and take a look at the boards and the caps. Check for bulging or leaking caps. Post some good images of your boards with your original question. For that use this guide. Since I only have the assembly instructions, substitute the assemble with disassemble
Esta resposta foi útil?
Pontuação 3
2 comentários:
I went ahead and tore it apart right after posting the question and not one of the caps had much for capacitance,they was toast.
por
Did you replace those?
por
Adicionar a sua resposta
shawn será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 17
Ao todo: 540
