Ir para o conteúdo principal
Uma edição atualizada do Samsung Galaxy S II lançada em 2013, identificável pelo número de modelo GT-I9105/P.
Screen cracked only glass replacement
I hav got a samsung s2 plus that has got a cracked screen the lcd and touch layer are fine . Is there any way to replace only the glass part?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
4 respostas
Solução escolhida
Hey Henrich, it is possible but it can be a mess to do. This video shows how to replace the glass for the s2 and this video shows the removal of the glass display for your specific device.
-You can purchase the glass-only display here:
http://www.ebay.com/itm/FREE-SHIP-for-Sa...
-Be careful to not damage the LCD.
-Let me know how it goes.
Esta resposta foi útil?
Pontuação 1
Thanks a lot I'll post some photos as soon as I'll have time to do it
Pontuação 1
Yes, you can fix the glass only if the lcd is still working. Go to youtube and search for glass repair on Samsung 2, there is tutorial there.
Pontuação 1
Sorry for the delay but the shipping took ages. So this is what the phone looked like
Imagem
the replacement screen came with a plastic spudger whitch was useless after 2minutes of using it so I used a knife instead (I know that its not the best idea but it worked out well)
Imagem
some progress
Imagem
the phone had a tape aplied whitch held the stock glass in I think that it might have been strong enough to hold the new glass but I bought some screen tape so I used that. After the stock screen was away i cleand the display with alcohol just to get any leftovers away. This is the final pruduct
Imagem
the colours of the display are fine but you can see glow from the capacitive buttons when you look at a certain angle this could have been fixed if i have had put the tape above the button. Also if someone wants to do this Id recommend getting a seethrough glue between the lcd and the glass just to make it look better and feel better and heat the glass often while taking it of it will go a lot better.
@iapple thanks a lot.
Sorry for my grammar Im not native
Pontuação 1
Adicionar a sua resposta
Henrich Hegedus será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 17
Ao todo: 1,080
