no command no charge help me
I have recently bought my Lenovo A7600-H
and i'm having problems and i can't charge it with my samsung charger. But when i do charge it says 'no command' i've been so sad since then.
Esta é uma boa pergunta?
You may want to replace the battery and hope for the best . If you did fry it by using the wrong charger it may have been only the battery that got damaged . I would start here and if you have no joy then you may want to look into replacing parts like the motherboard . You do realize just cause it fits doesnt mean you can use it ,every power unit has a specs chart on them somewhere and you need to make sure the specs are right for your particular device . Its always best to use only the charger that came with the device
Esta resposta foi útil?
Did you actually insert the Samsung charger into the device and plug the charger into the wall? If so, there's a good chance that you permanently damaged the device. See if you can obtain a logic board from the manufacturer of the device. Remember, just because a plug fits in a socket doesn't mean it's supposed to go there, and using the wrong charger can instantly fry a device.
press power button and wipe data factory then reboot
How is this done?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 525
