Ir para o conteúdo principal
Modelo A1278 de meados de 2010 / processador Core 2 Duo de 2,4 ou 2,66 GHz
Are Torx Security bits compatible with non-security bits?
I am looking to upgrade my wife's old Macbook Pro with an SSD, following this guide: Substituição do disco rígido do MacBook Pro 13" (corpo) monobloco meados de 2010
It says we need a T6 Torx screwdriver. I thought it was weird that the driver kits being sold by iFixIt wouldn't include anything higher than T5 for non-security Torx bits, but then I saw the following on this page: TR6 Torx Security Screwdriver
"Security drilling on this driver makes sure that you won't be stopped by anything, even though this driver still works great in non-security T6 screws as well."
So, can anyone confirm if Torx Security bits are compatible with Torx non-security bits, and does this hold true for all Torx bit sizes?
Imagem de Precision fixed blade screwdriver engineered by iFixit.
Produto
$5.99
Esta é uma boa pergunta?
Pontuação 9
Adicionar um comentário
2 respostas
Solução escolhida
The difference between security torx and standard torx is the hole drilled in the center, this allows the driver to slip over the pin located on the security screws. Otherwise they are identical sizes.
Esta resposta foi útil?
Pontuação 5
1 comentário:
is just the hole the difference? both share the same sizes?
por
Pergunta mais útil
Of course they are, all it is, is an extra hole.
Pontuação 7
Adicionar a sua resposta
Help Computer será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 22
Ao todo: 25,303
