Ir para o conteúdo principal
Um conjunto de guias e de ajudas para o reparo de lavadoras.
Washing Machine tripping electricity (RCD)
I have a Miele W5741 washing machine which is three years old.
The other day it tripped the electricity (RCD)
I found that it would trip the RCD every time regardless of what program I used.
After a few trials I have found the following: if I use the machine and select cold water (no heating of water) then it does not trip the electricity (RCD).
So my conclusion is that it is the heater that is causing the washer to trip the electricity! What do you think?
I opened up the front to locate the heater. However I don’t see how I can remove the heater as I see no screws!
Update (04/19/2016)
pics
Esta é uma boa pergunta?
Pontuação 3
Adicionar um comentário
3 respostas
Solução escolhida
Hi,
I agree that you heater element is faulty and should be replaced.
Looking at the pictures, and I'm only guessing, is the element being held in by the holding tension of the segmented 'washers' which seem to be around the heater element leads?
Here is a link showing a Miele washing machine heater element. This part will fit your model according to their model number compatibility checker. Hopefully it may help you to work out how to remove it.
http://www.partmaster.co.uk/miele/washin...
Esta resposta foi útil?
Pontuação 4
It does sound reasonable that its the element. A megger test, or an insulation resistance test should confirm this, once confirmed, a replacement part will repair it.
Pontuação 0
1 comentário:
the segmented screws will release the tension, prying the black rubber retainer aside will allow you to pull out the element. Obviously refit in the reverse order, being careful to remember what the order is.
por
I had the same problem with my 12 year old W3203. It was the heating element, which I sourced from eSpares for £94.
The YouTube videos on how to remove the front panel and replacing the element were easy to follow.
Pontuação 0
Adicionar a sua resposta
taylor será eternamente grato(a).
Visualizações:
Últimas 24 horas: 5
Últimos 7 dias: 18
Últimos 30 dias: 92
Ao todo: 25,389
