Ir para o conteúdo principal
Known as the ''PS2'', it is a sixth-generation video game console first released by Sony in Japan in March 2000. The United States saw it later in 2000 with the SCPH-30000. Repair of this device requires only common tools, but can get tricky.
186 Perguntas Visualizar todos
Why doesnt my ps2 allow me to play ps1 games?
I just bought a new ps1 game and for some reason it won't work on my ps2. Any time I try to play any PlayStation 1 game It won't allow me to. I don't think the problem is the games , I think it has to do with my PlayStation 2 , but nothing seems to be wrong with it .
Esta pergunta é pertinente?
Pontuação 1
1 dos comentários
If it's the PS2 slim you are experiencing issues with, then there is a solution. All you have to do is insert the PS1 game inside the PS2 console (while still off), and then press the power button three (3) times in a row. This should allow the PS1 game to be played on the PS2 slim. Hope this was helpful! :)
por
Adicionar um comentário
3 respostas
Solução escolhida
@sabrinag you of course made sure that the games match the region of your PS2. There were issues with the laser and the alignment on the PS2. The PS1 disks are a tad darker so in theory the laser is not strong enough to read through the darker discs from the PS1. You could try to adjust the laser and see if that will work. Take a look on here for that.
Esta resposta foi útil?
Pontuação 5
2 comentários:
I tried to clean and adjust the laser,but nothing seems to work. What else can I do
por
You could try and see if you can get a new assembly
por
download retro games from Gamulator
Pontuação 0
I used to face similar problems when I used to run some retro games from ROM Packs. It was strange since some of the games worked while some didn’t. I have asked several people regarding this problem but never solved it.
Pontuação 0
Adicionar a sua resposta
Sabrina será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 14
Últimos 7 dias: 116
Últimos 30 dias: 472
Duração total: 17,070
