Ir para o conteúdo principal
O Nintendo Wii U Pro Controller é um controle de videogame produzido pela Nintendo em 2012 para o console de jogos Wii U.
Wii u Pro Controller Responds late.
Help! My Wii U Pro Controller is functioning properly. But if I connect 2 wii remotes, it responds late. What do I do?
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
  1. How many receivers are on the Wii for the controllers? I am assuming that there are two receivers because each controller should have a specific controller receiver for each specific controller. If you only have one receiver then that is your issue the receiver is overtaxed trying to receive both controllers input. Also you might have a power issue, make sure both controllers have new/charged batteries. And yes rechargeable batteries do go bad with age. So if the rechargeable batteries are old you might want to get newer ones.
Esta resposta foi útil?
Pontuação 0
4 comentários:
There are 4 Receivers
por
And all of my batteries are new. They are not rechargeable and my Pro Controller is Fully charged. (I just bought the controller last month.)
por
If it is only one controller that is responding slow then did that one get thrown around? You might have to replace that specific controller. Also you could open it to see if it's logic board some how got a crack in it.
por
No. It didn't got thrown around. I've been taking it carefully since i've bought it. It works normal when a wii remote is connected, But if I connect two Wii remotes, It instantly responds slow.
por
Adicionar a sua resposta
andreiagreda será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 5
Ao todo: 259
