Ir para o conteúdo principal
A Kodak ESP 3 é uma impressora jato de tinta colorida multifuncional para fotos.
Printer won't "startup" when powered on
When I press the On button my printer begins to start but then stays in "Startup" mode and won't continue to boot up. To turn it off I have to unplug the power cord because none of the buttons on the control panel will work.
Esta é uma boa pergunta?
Pontuação 0
1 comentário
My printer is a Kodak ESP C310
por
Adicionar um comentário
1 resposta
Solução escolhida
Hi,
What is the exact model number of your printer, is it 3, 3.2 or 3.2s?
You may be able to fix your problem by reloading the firmware but because the firmware is different for the 3 models you need to install the correct one otherwise it may render your printer inoperable.
Here is the link for a Kodak ESP 3 printer firmware download, Windows OS.
http://support.en.kodak.com/app/answers/...
Here is the link for a Kodak ESP 3.2 printer firmware download, Windows OS.
Here is the link for a Kodak ESP 3.2s printer firmware download, Windows OS.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Randy Cantor será eternamente grato(a).
Visualizações:
Últimas 24 horas: 5
Últimos 7 dias: 8
Últimos 30 dias: 19
Ao todo: 2,496
