Why is my rear drivers wheel tilt in on top
My rear tire is tilted in on the top. What causes this? Can it be fixed?
Esta é uma boa pergunta?
That is called negative camber. Negative camber is when the top of the tire tucks inwards. For a road going car you typically want to maintain a slight amount of negative camber (1 – 2 Degrees) to improve road handling. Camber improves handling by allowing the tire to apply even loading when the body rolls going into a corner. A good Alignment shop can put in a kit to fix it or you could take a whack at it yourself. Cost a lot more than a regular alignment though.
Esta resposta foi útil?
Lower control arm.
W123 has adjustable camber on lower control arm to chassis mount via eccentric bolt.
Simple adjustment, aim for 0-1 degree negative.
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 8
Duração total: 767
