Ir para o conteúdo principal
Updated Apple TV with second generation A5 processor / Released March 7, 2012
32 Perguntas Visualizar todos
Apple TV bricked, blank
Moved Apple TV to older tv, it did not have HDMI. I used HDMI to Component cable.
Did not get anything. Moved back to previous location hooked it up as it was, and the screen is blank. Restored on iTunes to original factory setting, connected again and.. The screen is blank. What to do now?
Esta é uma boa pergunta?
Pontuação 1
1 comentário
Now your apple tv work with convertor? And HDMI connect does not work?
por
Adicionar um comentário
1 resposta
Solução escolhida
Hi,
Using a HDMI to component cable may have damaged the HDMI output circuitry of the Apple TV3 . You cannot convert a Digital video signal (HDMI) to an Analogue video signal (component) with just a cable connection. You need to use a converter such as in this example http://www.hdtvsupply.com/convert--hdmi-...
Here is one of many links regarding this problem.
http://www.hdtvsupply.com/hdmi-to-compon...
Esta resposta foi útil?
Pontuação 1
1 comentário:
Ok, may I somehow fix Apple TV After connecting wrong converter ? I have similar issue, and why it is bricked after upgrade not after connecting it to bad cable
por
Adicionar a sua resposta
milavic será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 8
Últimos 30 dias: 12
Duração total: 1,249
