Ir para o conteúdo principal
O Nokia Lumia 900 é um smartphone com Windows Phone 7.5, suporte a 4G LTE e uma tela sensível ao toque capacitiva ClearBlack AMOLED.
Can I change this flex?
Hi there, look, i've bought a nokia lumia 900 screen (all), but when i was trying to change it with the broken one, i accidentally broke the digitizer flex, so the screen works, but not the search, windows and back buttons.. is there any possibility to change only that thing (that entire flex, or module) with the screen that is broken? in the broken screen those 3 buttons are working fine..
Thanks!
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
Pergunta mais útil
Sure, but it would cost a fortune to repair a flex cable as a very expensive machine would be required to do this.
You're better off buying a new LCD + Digitizer. But if the glass can be easily replaceable withot damaging the LCD when separating the glass the. You can replace just the Digitizer.
Esta resposta foi útil?
Pontuação 2
1 comentário:
thanks! but now i've found that in some sites, they sell the navigation flex. I mean, if they sell it, it can change it, only that thing.. but, i dont know how to remove that, because in the broken one, all that "navigation flex cable" is perfect, and in the new one is broken.. sorry for my english, if you want i can send you some pictures..
por
Adicionar a sua resposta
Agustin Recoba será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 15
Ao todo: 302
