Ir para o conteúdo principal
The Claw is a small scale electronic arcade game with flashing LED lights. This candy and toy grabbing machine designed for home use.
Pergunta encerrada
What can it do
Does this machine play music?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
The claw is designed to work like many of the larger scale toy grabber machines. The major difference between The Claw and the grabbers you would find in an arcade is the size of the toys and candy that the device will be able to handle. It is a small scale device so small toys and candy items are recommended. With the use of the control levers, the claw will move around the glass case to reach and grab the candy or toy of your choice.
Esta resposta foi útil?
Pontuação 1
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 47
