How can I replace LCD Screen?
The Sony Vaio Duo 11 screen is blurred and some bubbles and must be replaced. I did not find service manuals on the Sony website.
How do I replace the LCD screen of my duo11. Someone has removed the screen of a 11 Duo or something similar?
Esta é uma boa pergunta?
https://www.screencountry.com/index.php?...
por Guenter Hildebrandt Compartilhar
Sadly, the link you provided says the item is now discontinued & it doesn't provide tech specs to help find an alt. supplier.
From searching to replace my(failing/delaminating AMOLED) orig screen, I found links on alibaba.com/aliexpress.com suggesting custom styled one of these (Panasonic VVX11F019G00) works as a replacement for a Sony Vaio Duo 11.
http://www.panelook.com/VVX11F019G00_Pan...
https://www.alibaba.com/product-detail/L...
https://www.aliexpress.com/item/NeoThink...
The only problem I can see is sourcing from a location that will sell them individually, or sourcing in the country I live in, so that if the claim of Duo 11 compatible isn't true, returning it won't result in losing money in shipping and import taxes. Will probably email a VVX11F019G00 ebay seller about one for a Duo 11 and report back if it works out.
por TankJr Compartilhar
Hi! I had the same problem and realized the replacement of the screen of my Vaio Duo 11 without problems. I got the full screen (with the touch digitizer) from EBAY and I followed this video from Sony that shows how the Duo 11 is mounted: https://youtu.be/2mLiCBhczTA
por Luiz Anesio Miranda Compartilhar
There is another place to try to found the screen: http://www.laptopinventory.com/ModelDeta...
Before buy, ask him if will work in our ultrabook.
And the correct model of your equipment is printed back the screen case (at the up right side).
Exibir mais 11 comentários
