Ir para o conteúdo principal
A standard cordless compact DeWalt 18V drill with a high performance motor that delivers 380 watts. Equipped with easy to hold design that allows you to work in difficult spaces.
10 Perguntas Visualizar todos
How do I tighten the chuck?
The chuck on my drill is wobbling, I need to make it stop.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
If your chuck is wobbling first check to see if the chuck is loose, if so tighten it by turning it clockwise. If that isn't the issue than the threads that allow the chuck to tighten may be caked with build up not allowing the chuck to fully tighten, to fix this remove the chuck and clear any build up. If that does not fix the wobbling issue either than your chuck is most likely defective it is advised you purchase and install a new one.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Jonathan Hamel será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 13
Duração total: 1,648
