Ir para o conteúdo principal
A Apple lançou o iPad Air, mais fino e potente, em 1 de novembro de 2013, nas cores Cinza Espacial ou Prateado. Ele vem equipado com o processador personalizado A7 e está disponível em configurações de 16, 32, 64 e 128 GB.
How to bypass the iPad passcode
Hello everyone! My grandmother just got an iPad recently and managed to put a passcode on it and not remember what the passcode is. I have tried putting the iPad into recovery mode and restoring it. However, there is an error every time I try to do this. In addition, I have tried using icloud. To erase the iPad, you need wifi and she has disabled it by trying her passcode to the point where it says "connect to itunes" like it is permanently disabled. PLEASE HELP!!!!
Esta é uma boa pergunta?
Pontuação 5
1 comentário
do i need to have an internet connection while doing this action and connect to the PC?
por Compartilhar
Adicionar um comentário
6 respostas
Pergunta mais útil
While you try to restore the I-pad, Take it to DFU mode and try to restore it.
DFU Mode: Press the Power button and Home Button at the same time till screen goes off,
After 5 secs of doing that, leave the power button and just press the home button till
it goes to DFU mode. After that, try to restore the I-Pad
Hope it Works.
Esta resposta foi útil?
Pontuação 2
Follow what Patrick said, make sure the iPad is DFU mode otherwise it will not work. Make sure you are using an original apple charging cord, if it doesn't work the first time try another charging cord or computer, sometime your settings on the computer will prevent the new software from going into the iPad properly.
Pontuação 1
If you wish on a star you can do anything in one click.
Pontuação 1
There is a "what" error when you try to restore?
Be specific enough please.
Pontuação 0
A program named 4uKey works for that issue.
bypass ipad passcode in 1 click.
Pontuação 0
1 comentário:
Can the program bring peace to the world in one click too ?
por Compartilhar
In such a situation, you can try an iPad passcode unlocker to help you. There are many such tools online. I have ever used one called Joyoshare iPasscode Unlocker to factory reset my locked iPad. It is easy to use. Of course, you can google this kind of unlocking tool and choose one that you desire.
Pontuação 0
Adicionar a sua resposta
morganmachado1 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 23
Últimos 30 dias: 62
Ao todo: 6,019
