Ir para o conteúdo principal
A versão mais recente da série Coolpix, a Nikon Coolpix S5300, foi anunciada em janeiro de 2014. O reparo deste dispositivo é semelhante ao de modelos anteriores e exigirá ferramentas como uma chave e uma ferramenta de abertura de plástico.
The camera doesn't charge
When I plug my camera in, it doesn't seem to be charging. What should I do?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
5 respostas
Rebecca,
I would make sure that the terminals on the battery are clean, you can use a pencil eraser to do this. I would then check to make sure the power supply / power cord that you have is functional. Is it powered via USB cable? USB mini and USB micro cables wear out and stop charging devices like they should, you can also check the power adapter that the USB cable plugs into to ensure it is putting out 5 volts as it should. The easiest way to check these things is to find a spare cable around the house and a spare AC to USB adapter around the house and swap one out at a time to find the culprit. I hope this helps.
Esta resposta foi útil?
Pontuação 0
2 comentários:
It could not open the shutter
por
It could not open the shutter if opened than after few miniuts it shws battery exhausted after long charging
por
Rebecca,
This could be the cause of a couple of things:
1) The battery could be dead: If this is the case then refer to our troubleshooting page section title "The camera won't turn on" this can be found here:
Nikon Coolpix S5300 Troubleshooting
2) If the camera still turns on, but the camera doesn't seem to charge the cord could be broken or the port could have something in it. Refer to our troubleshooting page section title "Not Charging" this can b found here:
Pontuação 0
1 comentário:
por
Get the charger wire strip it so that you would have the red and black wire separated take the battery out of your camera and put the negative wire on the negative metal part on the battery and the positive on the positive side and make sure it's taped or some on there then plug the wire up and let it charge the battery for about half an hour then take the wire off the battery and put the battery in the camera and it should come on if you did it
Pontuação 0
1 comentário:
Could not understand your answar charging code is not having +ve or -ne wire
por
I resolved the issue by using a different charging cube, the apple phone one seems not to provide the juice enough to charge the battery.
Pontuação 0
When we plug in crging code it shows charging but when we pull out the cable it start showing battery exhausted
Update (08/18/24)
Pontuação 0
Adicionar a sua resposta
Rebecca Field será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 20
Ao todo: 5,017
